TEGAM型号R1L-BR1连接强度计用于测量地面连接强度
关键词:TEGAM R1L-BR1连接强度计
时间:2013-03-07 15:11:17      来源:中电网
TEGAM型号R1L-BR1连接强度计是一种为特定目建造的,充电电池供电的,便携式仪器,用于测量地面连接强度。R1L-BR1具有 BCP-10开尔文探头,和KAK-1M开尔文Alligator KLIPS,全部装在一个坚固耐用的盒子里,使其在运输过程中免遭损害。它已被用于“基奥瓦勇士”武装侦察直升机。
The TEGAM Model R1L-BR1 bond meter is a purpose built, rechargeable battery powered portable instrument for ground bond measurements. The R1L-BR1 comes with BCP-10 Kelvin Probes and KAK-1M Kelvin Alligator Klips, all housed within a ruggedized case for protection during transport. It has been selected for deployment in support of the Kiowa Warrior Armed Reconnaissance Helicopter. The R1L-BR1 continues the history of excellence established by the inexpensive R1L-B and rugged R1L-BR, which are in inventory at each branch of the US military, and have more than 500 units currently fielded.
TEGAM’s Model R1L-BR1 can be used in a wide variety of applications outside the capabilities of other bond meters, including:
Fixed and rotary wing aircraft bond measurements in manufacturing and flight line maintenance operations where its high accuracy produces consistent results.
Verifying electromagnetic shield integrity between connector back shells.
Measure static discharge wicks for electrical continuity.
Inspect conductive coatings for coverage and thickness.
TEGAM’s Model R1L-BR1 has five ranges with full-scale values ranging from 2 milliohms to 20 ohms. Resolution on the lowest range is 1 microohm. Accuracy is 0.25% of reading ± 1 count. It is fully portable with rechargeable batteries that provide a full day of typical use. The operating temperature range is 0 °C to 50 °C.
More information about the Model R1L-BR1 Bond Meter Kit is available on the TEGAM website, http://www.tegam.com .
Price and Availability
The U.S. price for the R1L-BR1 is $2495.00, and units are available for immediate shipment.
