Maxim推出精密分路型基准电压LM4040
关键词:Maxim LM4040
时间:2013-03-11 16:34:31      来源:中电网
LM4040是一个精密,双端分路模式,带隙基准电压。其固定的反向击穿电压为2.048V,2.500V,3.000V,3.3V,4.096V,5.000V。非常适合空间有限的应用。LM4040为超小型,3引脚,SC70表面贴装封装(1.8毫米x 1.8毫米),它比同类器件(SOT23表面贴装封装)小50%,(SOT23版本也已上市)。
The LM4040 is a precision two-terminal shunt mode, bandgap voltage reference available in fixed reverse breakdown voltages of 2.048V, 2.500V, 3.000V, 3.3V, 4.096V, and 5.000V. Ideal for space-critical applications, the LM4040 is offered in the subminiature 3-pin SC70 surface-mount package (1.8mm x 1.8mm), 50% smaller than comparable devices in SOT23 surface-mount packages (SOT23 versions are also available).
Laser-trimmed resistors ensure precise initial accuracy. With a 100ppm/°C temperature coefficient, the device is offered in four grades of initial accuracy ranging from 0.1% to 1%. The LM4040 has a 60µA to 15mA shunt current capability with low dynamic impedance, ensuring stable reverse breakdown voltage accuracy over a wide range of operating temperatures and currents.
The LM4040 does not require an external stabilizing capacitor while ensuring stability with any capacitive load.
The LM4040 is guaranteed over the temperature range of -40°C to +125°C.
For a 1.225V output version, refer to the LM4041 data sheet.
LM4040
  • 主 题:确保医疗设备安全可靠的解决方案
  • 时 间:2025.06.18
  • 公 司:DigiKey&Littelfuse
  • 时 间:2025.06.24
