  • 首页 > 新品 > TI TLC59731是一个易于使用的3路50 mA反向电流LED驱动器
关键词:TI TLC59731 反向电流LED驱动器
时间:2013-03-28 15:48:43      来源:中电网
TLC59731是一个易于使用的,3路,50 mA反向电流LED驱动器。单丝,1 Mbps的串行接口(EasySet)提供了一个最大限度地减少布线成本的解决方案。 LED驱动器具有8位脉冲宽度调制(PWM)分辨率,和一个简单的伽玛校正功能。显示重复率达到3.1 kHz(典型值),并具有集成6 MHz灰阶(GS)时钟振荡器。
The TLC59731 is an easy-to-use, 3-channel, 50-mA sink current LED driver. The single-wire, 1-Mbps serial interface (EasySet) provides a solution for minimizing wiring cost. The LED driver provides 8-bit pulse width modulation (PWM) resolution and a simple gamma correction feature. The display repeat rate is achieved at 3.1 kHz (typ) with an integrated 6-MHz grayscale (GS) clock oscillator. The driver also provides unlimited cascading capability.
Output sink current can be set by each external resistor connected to the OUTn terminal in series. The TLC59731 has an internal shunt regulator that can be used for higher VCC power-supply voltage applications.
Features
Three Sink Current Channels Current Capability: 50 mA per Channel Grayscale (GS) Control with PWM: 8-Bit (256 Steps) with Simple Gamma Correction Single-Wire Interface (EasySet) Power-Supply (VCC) Voltage Range: No Internal Shunt Regulator Mode: 3 V to 5.5 V Internal Shunt Regulator Mode: 3 V to 6 V OUT Terminals Maximum Voltage: Up to 21 V Integrated Shunt Regulator Data Transfer Maximum Rate: Bits per Second (bps): 1 Mbps Internal GS Clock Oscillator: 6 MHz (typ) Display Repeat Rate: 3.1 kHz (typ) Output Delay Switching to Prevent Inrush Current Unlimited Device Cascading Operating Temperature: –40°C to +85°C
  • 时 间:2025.07.31
  • 公 司:NXP
  • 主 题:Abracon高精度时钟在测量仪器中的应用
  • 时 间:2025.08.19
  • 公 司:Abracon
