  • 首页 > 新品 > ARM和Cadence合作推出用于台积电16纳米FinFET制造工艺的ARMCortex-A57处理器
关键词:ARM Cadence 台积电16纳米 FinFET制造工艺 ARMCortex-A57处理器
时间:2013-04-09 10:34:37      来源:中电网
ARM和Cadence合作推出用于台积电16纳米FinFET制造工艺的ARMCortex-A57处理器,该测试芯片采用全部Cadence RTL-to-signoff流程,Cadence Virtuoso定制设计平台,ARM Artisan标准单元库,和台积电的内存宏。Cortex-A57处理器是ARM性能最高的处理器,它基于新的ARMv8架构
Fulfilling the promise of performance and power scaling at 16 nanometers, ARM and Cadence announced details behind their collaboration to implement the first ARM® Cortex®-A57 processor on TSMC’s 16-nanometer (nm) FinFET manufacturing process. The test chip was implemented using the complete Cadence RTL-to-signoff flow, Cadence Virtuoso custom design platform, ARM Artisan® standard cell libraries and TSMC’s memory macros.
在实现了16纳米幂刻尺度之后,ARM公司和Cadence公司宣布了他们合作的背景----落实第一款用于台积电16纳米(nm)FinFET制造工艺的ARM®Cortex-A57处理器。该测试芯片采用全部Cadence RTL-to-signoff流程,Cadence Virtuoso定制设计平台,ARM Artisan®标准单元库,和台积电的内存宏。Cortex-A57处理器是ARM性能最高的处理器,它基于新的ARMv8架构
The Cortex-A57 processor is ARM’s highest-performing processor to date, and is based on the new ARMv8 architecture, designed for computing, networking and mobile applications that require high performance at a low-power budget. TSMC’s 16nm FinFET technology is a significant breakthrough that enables continued scaling of process technology to feature sizes below 20nm. This test chip, developed with Cadence’s custom, digital and signoff solutions for FinFET process technology, was a collaboration that resulted in several innovations and co-optimizations between manufacturing process, design IP, and design tools.
“More than ever, success at the leading edge of innovation requires deep collaboration. When designing SoCs incorporating advanced processors, like the Cortex-A57, and optimizing the implementation using physical IP created for FinFET processes, the expertise of our partners is needed,” said Tom Cronk, executive vice president and general manager, Processor Division at ARM. “Our joint innovations will enable our customers to accelerate their product development cycles and take advantage of leading-edge processes and IP.”
The 16nm process using FinFET technology presented new challenges that required significant new development in the design tools. New design rules, RC extraction for 3D transistors, increased complexity of resistance models for interconnect and vias, quantized cell libraries, library characterization that supports new transistor models and double patterning across more layers are some of the challenges that have been addressed in Cadence’s custom, digital and signoff products.
“This major milestone was challenging on all fronts, requiring engineers from ARM, Cadence and TSMC to work as a unified team,” said Dr. Chi-Ping Hsu, senior vice president of R&D for the Silicon Realization Group at Cadence. “Our combined efforts and commitment to innovation will enable our customers to adopt the next generation of IP, process and design technology for designing high performance, low-power SoCs.”
  • 主 题:高集成伺服驱动系统与工业机器人方案
  • 时 间:2024.04.18
  • 公 司:ST
