  • 首页 > 新品 > Avago并行光学发射器和接收器模块AFBR-814VxyZ和AFBR-824VxyZ
关键词:Avago AFBR-814VxyZ AFBR-824VxyZ
时间:2013-04-23 10:38:20      来源:中电网
AFBR-814VxyZ和AFBR-824VxyZ是一组12通道,并行光学发射器和接收器模块,并对短距离并行多通道数据通信,和互连应用进行了优化。这些高速,高密度光模块,可用于,采用标称波长为850 nm的多种光纤系统
The AFBR-814VxyZ and AFBR-824VxyZ are a set of 12-channel parallel optics transmitter and receiver modules optimized for short-range parallel multi-lane data communication and interconnect applications. These high-speed, high-density optical modules are designed to operate over multimode fiber systems using a nominal wavelength of 850 nm.
Avago’s MiniPOD solution offers system designers two module package options to optimize their cable management and board layout. AFBR-814RxyZ Tx/AFBR-824RxyZ Rx is used with round multi-lane cable assemblies for applications requiring multiple turns of the jumper cable inside the chassis. AFBR-814FxyZ Tx/AFBR-824FxyZ Rx is used with flat ribbon cable assemblies, allowing dense tiling of the modules as the jumper cables can be thread under the dust-cap of the next module. This top mounted optical connection maximizes board layout density by eliminating board space lost to the optical connector and strain relief.
The electrical interface uses a 9×9 MEG-Array connector with 1.27 mm pitch
http://portal.fciconnect.com/Comergent/fci/drawing/55714.pdf?WR.mc_id=EEweb_2013
The optical interface requires the user to provide a custom designed optical turn 1×12 ribbon cable PRIZM® LightTurn® connector.
The thermal interface provided can require either a user provided heat sink or use of the Avago general purpose clip on heat sink, to maintain the module case temperature to be between 0°C to 70°C during continuous operation.
Selected Features
Compatible with 12×FDR InfiniBand Compliant to IEEE 802.3ba 100GbE (100GBASE-SR10 and nPPI) per lane Operates at 10 Gbps with 8b/10b encoded data, for IB-QDR application, 10.3125 Gbps for 100GbE, and up to 14.0625 Gbps for IB-FDR with 64b/66b encoded data High Aggregate bandwidth: 168 Gbps per module High density footprint: 21.95 mm × 18.62 mm size Two package options to optimize internal cable management and system layout Separate transmitter and receiver modules 850 nm VCSEL array in transmitter; PIN array in receiver Using OM4 4700 MHz∙km fiber: links up to 150 m, from 10.3125 Gbps to 11.5 Gbps, 100 m 12.5 Gbps, and 50m 14.0625 Gbps
  • 主 题:确保医疗设备安全可靠的解决方案
  • 时 间:2025.06.18
  • 公 司:DigiKey&Littelfuse
  • 时 间:2025.06.24
