  • 首页 > 新品 > Intersil推出高性能临界导电模式(CrCM)反激式控制器ISL1904
关键词:Intersil 临界导电模式 CrCM 反激式控制器 ISL1904
时间:2013-05-13 14:11:19      来源:中电网
ISL1904是一个高性能,临界导电模式(CrCM),反激式控制器,用于交流电源的单级转换及具有功率因数校正(PFC)的恒定电流源。该控制器通过监测初级端开关电流调节输出电流,所以反馈信号不穿过隔离层。
The ISL1904 is a high-performance, critical conduction mode (CrCM), flyback controller used for single-stage conversion of the AC mains to a constant current source with power factor correction (PFC). The controller regulates the output current by monitoring the primary side switching current so the feedback signal does not cross the isolation barrier. Operation in CrCM allows near zero-voltage quasi-resonant switching (ZVS) for improved efficiency while maximizing magnetic core utilization. The ISL1904 LED driver provides all of the features required for high-performance dimmable LED ballast designs and supports AC or DC input, isolated or non-isolated flyback and boost topologies. This advanced BiCMOS controller features all of the functions required to design low cost low parts count LED driver.
KEY FEATURES
Excellent LED current regulation over line, load, and temperature
0 – 100% dimming with leading-edge (triac) and trailing-edge dimmers
Power factor correction for up to 0.995 power factor and less than 20% harmonic content
Critical conduction mode (CrCM) operation for quasi-resonant high efficiency performance
Supports universal AC mains input
Configurable for PWM or DC current dimming control of LEDs
Monitors FET switching current for load regulation
Supports isolated and non-isolated boost and flyback topologies
Closed loop soft-start for no overshoot
OFFREF feature to set dimming off-point to improve fixture performance matching
-40°C to +125°C operation
Pb-free (RoHS compliant)
APPLICATIONS
Industrial and commercial LED lighting
Retrofit LED lamps with triac dimming
Universal AC mains input LED retrofit lamps
AC or DC Input LED ballasts
  • 时 间:2024.04.11
  • 公 司:ADI&Arrow
  • 主 题:高集成伺服驱动系统与工业机器人方案
  • 时 间:2024.04.18
  • 公 司:ST
