TI推出可调三端正电压稳压器LM317
关键词:TI LM317
时间:2013-05-20 15:01:35      来源:中电网
TI推出可调三端正电压稳压器LM317,在输出电压范围为1.25 V至37 V时,能够提供超过1.5A的输出,该稳压器非常容易使用,只需要两个外部电阻来设定输出电压。
The LM317 is an adjustable three-terminal positive-voltage regulator capable of supplying more than 1.5 A over an output-voltage range of 1.25 V to 37 V. It is exceptionally easy to use and requires only two external resistors to set the output voltage. Furthermore, both line and load regulation are better than standard fixed regulators.
In addition to having higher performance than fixed regulators, this device includes on-chip current limiting, thermal overload protection, and safe operating-area protection. All overload protection remains fully functional, even if the ADJUST terminal is disconnected.
The LM317 is versatile in its applications, including uses in programmable output regulation and local on-card regulation. Or, by connecting a fixed resistor between the ADJUST and OUTPUT terminals, the LM317 can function as a precision current regulator. An optional output capacitor can be added to improve transient response. The ADJUST terminal can be bypassed to achieve very high ripple-rejection ratios, which are difficult to achieve with standard three-terminal regulators.
Features
Output Voltage Range Adjustable From 1.25 V to 37 V Output Current Greater Than 1.5 A Internal Short-Circuit Current Limiting Thermal Overload Protection Output Safe-Area Compensation
  • 主 题:确保医疗设备安全可靠的解决方案
  • 时 间:2025.06.18
  • 公 司:DigiKey&Littelfuse
  • 时 间:2025.06.24
