TI推出6.3 V,3 A同步降压转换器TPS50301
关键词:TI 同步降压转换器 TPS50301
时间:2013-06-05 15:22:42      来源:中电网
TPS50301是一个6.3 V,3 A同步降压转换器,TPS50601是一个6.3-V,6 A同步降压转换器,它们通过高侧,和低侧MOSFET高效率的集成,进行了优化,适用于小型化设计。通过电流模式控制,进一步节省了空间,减少了元件数量,高开关频率,降低了电感的占位。该器件采用了增强耐热,20引脚陶瓷,双列直插式扁平包装
The TPS50301 is a 6.3-V, 3-A and the TPS50601 is a 6.3-V, 6-A synchronous step down converter which is optimized for small designs through high efficiency and integrating the high-side and low-side MOSFETs. Further space savings are achieved through current mode control, which reduces component count, and a high switching frequency, reducing the inductor’s footprint. The devices are offered in a thermally enhanced 20-pin ceramic, dual in-line flatpack package.
The output voltage startup ramp is controlled by the SS/TR pin which allows operation as either a stand alone power supply or in tracking situations. Power sequencing is also possible by correctly configuring the enable and the open drain power good pins.
Cycle by cycle current limiting on the high-side FET protects the device in overload situations and is enhanced by a low-side sourcing current limit which prevents current runaway. There is also a low-side sinking current limit which turns off the low-side MOSFET to prevent excessive reverse current. Thermal shutdown disables the part when die temperature exceeds thermal shutdown temperature.
Features
Peak Efficiency: 95% (VO = 3.3 V) Integrated 55-mΩ/50-mΩ MOSFETs Split Power Rail: 1.6 V to 6.3 V on PVIN Power Rail: 3 V to 6.3 V on VIN TPS50301-HT: 3 A TPS50601-SP: 6 A TPS50601-SP: SEL Latchup Immune to LET = 85 MeV-cm2/mg TPS50601-SP: Total Dose (TID) tolerance = 100kRad (Si) Flexible Switching Frequency Options: 100-kHz to 1-MHz Adjustable Internal Oscillator External Sync Capability from 100 kHz to 1 MHz Sync Pin Can Be Configured as a 500-kHz Output for Master/Slave Applications 0.795-V ±1.258% Voltage Reference at 25°C Monotonic Start-Up into Pre-Biased Outputs Adjustable Slow Start and Power Sequencing Power Good Output Monitor for Undervoltage and Overvoltage Adjustable Input Undervoltage Lockout For SWIFT Documentation, Visit http://www.ti.com/swift
  • 主 题:确保医疗设备安全可靠的解决方案
  • 时 间:2025.06.18
  • 公 司:DigiKey&Littelfuse
  • 时 间:2025.06.24
