Avago推出冷白扩散ASMT-MWH0 NEG001/2W功率LED发射器
关键词:Avago 冷白扩散 ASMT-MWH0 NEG001/2W功率 LED发射器
时间:2013-06-26 15:02:38      来源:中电网
冷白扩散ASMT-MWH0 NEG001/2W功率LED发射器,是一种高性能的高效节能大功率LED,它可以处理高温和高驱动电流。其裸露焊盘设计,具有优良的散热性能(从封装转移到主板)。并具有电隔离金属嵌片选项
The Cool White Diffused ASMT-MWH0-NEG00 1/2W Power LED emitter is a high performance energy efficient power LED which can handle high temperature and high driving current. The exposed pad design has excellent heat transfer from the package to the motherboard. An option with an electrically isolated metal slug is also available.
The Cool White Power LED is available in various color temperature ranging from 4000K to 10000K and Warm White Power LED ranging from 2600K to 4000K. The low profile package design serves many applications, especially where height is a constraint.
The package is compatible with reflow soldering. This gives the light source designer more freedom and flexibility.
Features
• Available in Cool White & Warm White color
• Available in diffuse and non-diffuse version
• Available in both electrical isolated and non-isolated metal slug
• Energy efficient
• Exposed pad for excellent heat transfer
• Suitable for reflow soldering process
• High current operation
• Long operation life
• Wide viewing angle
• Silicone encapsulation
• ESD HBM Class 3B, > 8000
• MSL 4 products
  • 时 间:2024.04.11
  • 公 司:ADI&Arrow
  • 主 题:高集成伺服驱动系统与工业机器人方案
  • 时 间:2024.04.18
  • 公 司:ST
