Maxim推出MAX19997A双通道下变频混频器
关键词:Maxim MAX19997A 变频混频器
时间:2013-03-18 11:02:20      来源:中电网
MAX19997A双通道下变频混频器是一个多功能的,高度集成的,多样性下变频器,具有高线性度,和低噪声系数,可应用于1800MHz至2900MHz的多种基站。
The MAX19997A dual downconversion mixer is a versatile, highly integrated diversity downconverter that provides high linearity and low noise figure for a multitude of 1800MHz to 2900MHz base-station applications. The MAX19997A fully supports both low- and high-side LO injection architectures for the 2300MHz to 2900MHz WiMAX™, LTE, WCS, and MMDS bands, providing 8.7dB gain, +24dBm input IP3, and 10.3dB NF in the low-side configuration, and 8.7dB gain, +24dBm input IP3, and 10.4dB NF in the high-side configuration. High-side LO injection architectures can be further extended down to 1800MHz with the addition of one tuning element (a shunt inductor) on each RF port.
The device integrates baluns in the RF and LO ports, an LO buffer, two double-balanced mixers, and a pair of differential IF output amplifiers. The MAX19997A requires a typical LO drive of 0dBm and a supply current guaranteed below 420mA to achieve the targeted linearity performance.
The MAX19997A is available in a compact 6mm x 6mm, 36-pin thin QFN lead-free package with an exposed pad. Electrical performance is guaranteed over the extended temperature range, from TC = -40°C to +100°C.
Key Features
1800MHz to 2900MHz RF Frequency Range 1950MHz to 3400MHz LO Frequency Range 50MHz to 550MHz IF Frequency Range Supports Both Low-Side and High-Side LO Injection 8.7dB Conversion Gain +24dBm Input IP3 10.3dB Noise Figure +11.3dBm Input 1dB Compression Point 70dBc Typical 2 × 2 Spurious Rejection at PRF = -10dBm Dual Channels Ideal for Diversity Receiver Applications Integrated LO Buffer Integrated LO and RF Baluns for Single-Ended Inputs Low -3dBm to +3dBm LO Drive Pin Compatible with the MAX19999 3000MHz to 4000MHz Mixer Pin Similar to the MAX9995 and MAX19995/MAX19995A 1700MHz to 2200MHz Mixers and the MAX9985 and MAX19985A 700MHz to 1000MHz Mixers 42dB Channel-to-Channel Isolation Single 5.0V or 3.3V Supply External Current-Setting Resistors Provide Option for Operating Device in Reduced-Power/Reduced-Performance Mode
MAX19997A
