Avago AFCT-57J5APZ光学收发器支持高速串行链路
关键词:Avago AFCT-57J5APZ 光学收发器 高速串行链路
时间:2013-03-25 14:51:26      来源:中电网
Avago的AFCT-57J5APZ光学收发器支持高速串行链路(通过单模光纤),其最高信号传输速率为3.7GB/s,用于无线基站,包括OBSAI和CPRI协议以及相关的应用程序。
The Avago AFCT-57J5APZ optical transceiver supports high speed serial links over single mode optical fiber at signaling rates up to 3.7Gb/s for wireless base station ap­plications involving the OBSAI or CPRI protocols, as well as related applications.
The transceiver is compliant with Small Form Pluggable (SFP) multi-source agreements INF-8074 and SFF-8472 for mechanical and electrical specifi­cations and FOCIS/IEC specifications for optical duplex LC
Features
Fully RoHS Compliant Diagnostic Features Per SFF-8472 “Diagnostic Monitoring Interface for Optical Transceivers” Real time monitors of: Transmitted Optical Power Received Optical Power Laser Bias Current Temperature Supply Voltage Industrial Temperature and Supply Voltage Operation (-40°C to 85°C) (3.3V ± 10%) Transceiver Specifications per SFP (INF-8074) and SFF-8472 (revision 10.4) Up to 7km with SMF at 3.70Gb/s Up to 7km with SMF at 3.072 Gb/s Up to 8km with SMF at 2.457 Gb/s LC Duplex optical connector interface conforming to ANSI TIA/EIA604-10 (FOCIS 10A) 1310nm FP (Fabry Perot) Source Technology IEC 60825-1 Class 1/CDRH Class 1 laser eye safe
Compatible with Fibre Channel and Gigabit Ethernet applications
  • 时 间:2025.07.31
  • 公 司:NXP
