NXP LM75A是温度数字转换器
关键词:NXP LM75A 温度数字转换器
时间:2013-04-02 11:15:02      来源:中电网
LM75A是温度数字转换器,它采用了一个片上带隙温度传感器,和Sigma-delta A--D转换技术。该器件还是一个热探测器,具有输出过温检测。 LM75A包含了许多数据寄存器:配置寄存器(CONF),以存储设备的设置,如,器件的工作模式,OS工作模式,OS极性和OS故障队列(第7章“功能说明”; 中描述),温度寄存器(TEMP),以存储数字温度读数,设定点寄存器(Tos和THYST)以存储可编程过热关断和滞后限制(通过2线串行I²C总线接口,可
The LM75A is a temperature-to-digital converter using an on-chip band gap temperature sensor and Sigma-delta A-to-D conversion technique. The device is also a thermal detector providing an overtemperature detection output. The LM75A contains a number of data registers: Configuration register (Conf) to store the device settings such as device operation mode, OS operation mode, OS polarity and OS fault queue as described in Section 7 “Functional description”; temperature register (Temp) to store the digital temp reading, and set-point registers (Tos and Thyst) to store programmable overtemperature shutdown and hysteresis limits, that can be communicated by a controller via the 2-wire serial I²C-bus interface. The device also includes an open-drain output (OS) which becomes active when the temperature exceeds the programmed limits. There are three selectable logic address pins so that eight devices can be connected on the same bus without address conflict.
The LM75A can be configured for different operation conditions. It can be set in normal mode to periodically monitor the ambient temperature, or in shutdown mode to minimize power consumption. The OS output operates in either of two selectable modes: OS comparator mode or OS interrupt mode. Its active state can be selected as either HIGH or LOW. The fault queue that defines the number of consecutive faults in order to activate the OS output is programmable as well as the set-point limits.
The temperature register always stores an 11-bit 2’s complement data giving a temperature resolution of 0.125 Cel. This high temperature resolution is particularly useful in applications of measuring precisely the thermal drift or runaway.
The device is powered-up in normal operation mode with the OS in comparator mode, temperature threshold of 80 Cel and hysteresis of 75 Cel, so that it can be used as a stand-alone thermostat with those pre-defined temperature set points.
Features and Benefits
Pin-for-pin replacement for industry standard LM75 and offers improved temperature resolution of 0.125 Cel and specification of a single part over power supply range from 2.8 V to 5.5 V Small 8-pin package types: SO8 and TSSOP8 I²C-bus interface with up to 8 devices on the same bus Power supply range from 2.8 V to 5.5 V Temperatures range from -55 Cel to +125 Cel 11-bit ADC that offers a temperature resolution of 0.125 Cel Temperature accuracy of: +-2 Cel from -25 Cel to +100 Cel +-3 Cel from -55 Cel to +125 Cel Programmable temperature threshold and hysteresis set points Supply current of 3.5 uA in shutdown mode for power conservation Stand-alone operation as thermostat at power-up ESD protection exceeds 2000 V HBM per JESD22-A114, 200 V MM per JESD22-A115 and 1000 V CDM per JESD22-C101 Latch-up testing is done to JEDEC Standard JESD78 which exceeds 100 mA
