Power节能能离线式开关TinySwitch-4
关键词:Power MOSFET TinySwitch-4
时间:2013-04-10 16:28:22      来源:中电网
由于具有线路补偿过载功率保护, TinySwitch-4器件大幅降低了通用输入电压的最大过载,这特别有助于,PC的待机和CV适配器,以限制过载故障状态时的最大输出功率。TinySwitch-4还集成了一个725 V MOSFET,可以容许高反射电压和高总线电压降低80%。
With line-compensated overload power protection, TinySwitch-4 devices dramatically reduce the maximum overload variation over the universal input voltage range. It is particularly helpful in applications such as PC standby and CV adapters to limit the maximum output power during the overload fault condition. TinySwitch-4 also incorporates a 725 V MOSFET that easily allows 80% de-rating for high reflected voltage and high bus voltage designs. The BP/M pin permits the MOSFET current limit to be adjusted up or down, allowing designers to optimize power delivery and efficiency in a variety of physical implementations. An on-time extension function extends the low-line regulation range, enabling hold-up time to be met with lower values of input capacitance.
Product Highlights
Lowest System Cost with Enhanced Flexibility
725 V rated MOSFET Increases BV de-rating margin Line compensated overload power – no additional components Dramatically reduces max overload variation over universal input voltage range
±5% turn on UV threshold: line voltage sense with single external resistor Simple ON/OFF control, no loop compensation needed Selectable current limit through BP/M capacitor value Allows optimum TinySwitch-4 choice by swapping devices with no other circuit redesign Tight I2f parameter tolerance reduces system cost Maximizes MOSFET and magnetics utilization ON-time extension – extends low-line regulation range/hold-up time to reduce input bulk capacitance Self-biased: no bias winding or bias components Frequency jittering reduces EMI filter costs
Enhanced Safety and Reliability Features
Accurate hysteretic thermal shutdown protection with auto¬matic recovery eliminates need for manual reset Auto-restart delivers <3% of maximum power in short-circuit and open loop fault conditions Output overvoltage shutdown with optional Zener Fast AC reset with optional UV external resistor Very low component count enhances reliability and enables single-sided printed circuit board layout High bandwidth provides fast turn-on with no overshoot and excellent transient load response
EcoSmart™ – Energy Efficient
Easily meets all global energy efficiency regulations No-load <30 mW with bias winding, <150 mW at 265 VAC without bias winding
ON/OFF control provides constant efficiency down to very light loads – ideal for mandatory CEC regulations and EuP standby requirements
Applications
PC Standby and other auxiliary supplies DVD/PVR and other low power set top decoders Supplies for appliances, industrial systems, metering, etc Chargers/adapters for cell/cordless phones, PDAs, digital cameras, MP3/portable audio, shavers, etc.
  • 时 间:2025.07.31
  • 公 司:NXP
