NXP推出一个边带信号多路复用器CBTL03SB212
关键词:NXP CBTL03SB212 DisplayPort
时间:2013-05-13 13:58:04      来源:CBTL03SB212
CBTL03SB212是一个边带信号多路复用器,用于DisplayPort的Gen2。它具有一个差分通道,可切换或复用(双向及交流耦合)DisplayPort1.2 Fast AUX, 或 AUX信号(采用高带宽通门技术)。
The CBTL03SB212 is a sideband signal multiplexer for DisplayPort Gen2 applications. It provides one differential channel capable of switching or multiplexing (bidirectional and AC-coupled) DisplayPort 1.2 Fast AUX or AUX signal, using high-bandwidth pass-gate technology. Additionally, it provides for switching/multiplexing of the Hot Plug Detect signal as well as the Display Data Channel (DDC) signals, for a total of three channels.
A typical application of CBTL03SB212 is on motherboards where one of two GPU display sources needs to be selected to connect to a display sink device or connector. A controller chip selects which path to use by setting a select signal HIGH or LOW. Due to the non-directional nature of the signal paths (which use high-bandwidth pass-gate technology), the CBTL03SB212 can also be used in the reverse topology, e.g., to connect one display source device to one of two display sink devices or connectors.
Features and benefits
1 : 2 multiplexing of DisplayPort signals
      1 high-speed differential channel for Fast AUX or AUX
      1 channel for DDC clock and data
      1 channel for HPD
High-bandwidth analog pass-gate technology
Very low intra-pair differential skew (5 ps typical)
Switch/MUX position select
Shutdown mode CMOS input
Shutdown mode minimizes power consumption while switching all channels off
Very low operation current of 0.2 mA typical
Very low shutdown current of < 10 μA
Single 3.3V power supply
ESD 4 kV HBM, 1 kV CDM
Available in 4 mm × 4 mm HVQFN20 package
  • 时 间:2025.07.31
  • 公 司:NXP
