IXYS 电源控制的AGT平台
关键词:IXYS AGT平台
时间:2013-07-04 17:05:37      来源:中电网
阳极门控晶闸管(AGT),与一个标准晶闸管(如CLA30E1200HB)的结合,可以提供了一些有趣的配置。晶闸管相腿配置(Thyristor phase-leg)通常包含两个分离的栅极驱动器电位,但,通过AGT更换一个晶闸管,它会降到只有一个栅极驱动器电位。这将节省一个完整的栅极驱动器电路。
The combination of the Anode Gated Thyristor (AGT) together with a standard thyristor (e.g. the CLA30E1200HB), gives several interesting configurations. Thyristor phase-leg configurations normally contain two separated gate driver potentials, but by replacing one thyristor with the AGT, it will reduce to only one gate driver potential. This will save one complete gate driver circuit. Also an AC switch configuration benefits from the AGT. Here the switch can be operated with only one gate drive circuit. This shows great cost saving possibilities by reducing the gate drive component count. Therefore it will also have a positive impact on the Mean Time To Failure (MTTF) in the final application.
The AGT platform has similar electrical specification as the standard thyristor and is not limited to the 1200V/30A ratings of the CLB30I1200HB. In the future, various die sizes with higher and lower current/voltage ratings are planned to complete the AGT product portfolio. This new Thyristor Platform is made possible by IXYS’ known and proven thyristor technologies and in-house production methods.
Several applications are targeted by the Anode Gated Thyristor such as line rectifying, soft-starters, motor control, AC power/lighting and temperature control. Generally, power control applications that use TRIACs, or thyristors are ideal for the use of this AGT, with simplified design and better performance.
