Mikme:让你拥有录音棚集的音质
关键词:Mikme 无线录音话筒 Bluetooth 2.1
时间:2015-06-29 13:37:58      来源:中电网
Mikme是世界上第一个完全无线录音话筒,能捕捉24Bit/96KHz高质量音频,还内置了蓝牙连接,兼容iOS及Android设备,可以实时录音回放、编辑,还能作为电脑的蓝牙麦克风。
Mikme是世界上第一个完全无线录音话筒,你只需轻点Mikme,它便能捕捉高质量音频!
Mikme非常小巧便于携带。其内置蓝牙连接,兼容iOS及Android设备,你可以将音乐通过Mikme应用程序进行编辑,调整,和共享等功能,还可以将它作为电脑的蓝牙麦克,内置的8GB闪存足以储存180小时高质量音频,电池寿命也达到7小时,完全可以满足用户一天内的录音需求。
Audio
Capsule – 1 inch, gold plated, true condenser
Polar pattern – Cardiod
Audio frequency bandwidth – 20 to 20000 Hz
Sensitivity – 18 mV/Pa
Signal to noise – 78 dB-A
Maximum Sound Pressure Level – 145dB
Preattenuation pad – 0 to -30 dB
Internal Audio Recorder
Internal memory – 8 GB
Recording time –  180 hours MP4, 16 hours WAV
Bit depth – 24
Sampling frequencies – 44.1 kHz, 48 kHz, 96 kHz
Processor – 168 MHz Cortex M4
Rechargeable Li-IO battery – 1000 mAh
Battery-powered operation time standalone recording – 7 hours
Bluetooth
Bluetooth 2.1
Battery-powered operation time with bluetooth recording – 5 hours
Wireless – Bluetooth Mikme Lost & Found Protocol
Immediate Secure Audio Transmission with patent pending Packet Loss and Sync Detection = Quality of Service Audio Streaming
Works with
Devices with iOS 8 and newer (with installed MIKME app)
Devices with Android 5.0 (Lollipop) and newer (with installed MIKME app) - Fall 2015 available
Wireless – Bluetooth Standard
Standard Audio Transmission via HFP and A2DP
Works with
All devices compatible with Bluetooth 2.1 (iOS, Android, Windows, Mac OS X...)
Wired – Micro USB Connector
Works with
Windows XP and higher with USB 2.0
Mac OS 10.8 and higher with USB 2.0
iOS 8 and newer
Audio Out 3.5mm Mini Jack
Low latency monitoring of
  Microphone capsule audio signal
  Playback audio signal from Mikme App
  Mix balance adjustable via Mikme App
Used for
  Headphones Monitoring
  Stereo audio out to DSLR or mixer
Mounting
3/8'thread for microphone stands
1/4'thread for DSLR tripods and mic stands
Dimensions and Weight
70 mm (2,75") x 70 mm (2,75") x 35 mm (1,4")
200 g (0.4lbs) Weight
