  • 首页 > 新品 > IXYS推出了ISOPLUSTM表面贴装功率器件(SMPD)系列的最新产品
关键词:IXYS ISOPLUSTM 表面贴装功率器件 SMPD
时间:2013-03-05 17:24:09      来源:中电网
IXYS公司宣布,该公司推出了ISOPLUSTM表面贴装功率器件(SMPD)系列的最新产品,该产品为需要将绝缘栅双极晶体管(IGBT),半导体闸流管,和快恢复二极管集成在一个电路上的设计人员成功地减少了分立器件的数量。这一专利的SMPDModule平台成功地提高了可靠性,并减小了电路板尺寸……
IXYS Corporation announced the release of its latest addition to the ISOPLUSTM Surface Mount Power Device (SMPD) range which successfully reduces the amount of discrete devices for designers that need to apply Insulated Gate Bipolar Transistors (IGBT), thyristor and fast diode technologies in one circuit.
The patented SMPDModule platform has successfully improved reliability and reduced board size by offering surface mount solutions for systems up to 15kW. Using IXYS’ proprietary DCB isolated substrates the SMPD Module flexibility provides a platform for mixed technology and multiple die content, e.g., thyristor, IGBT, MOSFET and diode in boost, buck, parallel, half bridge, full and three phase bridges or two switches side by side topologies.
“Incorporating our thyristors with our IGBT’s has been a natural extension of our depth in power semiconductor technologies. The thyristors have been the highest power density switches for the industry and are relatively easy to drive as high side switches in bridge configuration. They conduct higher currents with higher efficiencies than FETs and IGBTs, thus a combination with FETs or IGBTs creates almost an ideal switch, where the high-sidehigh currents, are conducted by the thyristors, and high speed switching is done with the low side IGBTs in this product,” commented Dr. Nathan Zommer, CEO of IXYS Corporation. “More combinations of these technologies are possible, and will be introduced to our customers needs as applications power devices (ASPD)”.
Integration of the thyristor into a half bridge with an IGBT provides a one-stop solution for power designers needing to operate a low frequency bridge (thyristor) with higher frequency modulation (IGBT). The example of the IXA20PT1200LB is a 20A, 1200V SMPD surface mountable module which contains a thyristor at the high side and IGBT technology on the low side of a half bridge circuit allowing an energy efficient solution for applications such as current source micro-inverter, UPSs, power supplies, motor drives and medical applications.
“This latest release illustrates the true attraction of the SMPD Module platform to our customers,” commented Bradley Green, President of European Sales and Business Development. “Combining any number of our rugged, power efficient die technologies into innovative topologies and packing them in our surface mount, pick-and-place ready module platform for energy sensitive applications is a true differentiator.”
“The SMPD Module is a platform that provides ‘solution-scale’ resolution to power problems by reducing board real estate requirement and component count and weight and power loss due to parasitic inductance. We will continue to develop products which resonate with customers’ demand for MORE POWER – LESS PACKAGE and IXYS fully intends to retain the leading edge in providing innovation in this field,” Mr. Green continued. For more information on this product innovation please go to the below link on the IXYS
web-site: http://ixapps.ixys.com/DataSheet/IXA20PT1200LB.pdf.
ISOPLUSTM
