  • 首页 > 新品 > Maxim推出MAX2181A高度集成的FM可变增益低噪声放大器
关键词:Maxim MAX2181A 低噪声放大器
时间:2013-03-21 17:04:37      来源:中电网
MAX2181A是一款高度集成的FM可变增益低噪声放大器,非常适用于汽车FM,和FM多样性的有源天线。该器件具有一个FM信号路径,提供30dB的增益范围,由片上功率检测器控制。
The MAX2181A is a highly integrated FM variable-gain low-noise amplifier ideal for use in automotive FM and FM-diversity active antenna applications. The device features an FM signal path, providing 30dB of gain range, controlled by an on-chip power detector. The FM signal path covers 76MHz to 162.5MHz.
The device is available in a small, 3mm x 3mm, TQFN package and operates over the extended industrial temperature range (-40°C to +85°C).
Key Features
+5V Supply Voltage Integrated AGC Function Eliminates External Pin Diodes High Dynamic Range Low-Noise, Sub 3dB Noise Figure Low External BOM Small Package (3mm x 3mm TQFN) Integrated Power Detector
  • 时 间:2025.01.14
  • 公 司:ADI&DigiKey
