Alpha和Omega半导体有限公司推出了AOZ1948器件
关键词:Alpha Omega AOZ1948器件
时间:2013-03-21 17:06:24      来源:中电网
Alpha 和 Omega半导体有限公司推出了AOZ1948器件(单一通道降压型LED控制器)。它具有LED调光解决方案,和完整的线性(从100%到1%)。
Alpha and Omega Semiconductor Limited released the AOZ1948, a single channel buck LED controller which features LED dimming resolution with full linearity from 100% to 1%, in addition to added integrated circuit protection capabilities for improved system solution robustness and reliability. The device is able to support VIN levels from 9V to 500V which makes it ideally suited for AC/DC lighting applications such as general lighting for commercial and industrial environments, and backlighting for next generation LED TVs.
The AOZ1948 combines key performance and device safety features for improved solution reliability and robustness. The device’s current control method provides a best-in-class LED current regulation of better than 2% and supports duty cycles up to 90%. In addition, the AOZ1948 integrates many fault detection and safety features such as over-current protection, auto-restart OCP, thermal overload, and high voltage sensing and adjustable fault timer.
“I am excited about the market prospect for the AOZ1948, our first step-down LED controller IC for advanced lighting solutions.” said Wayne Eng, Director of Product Marketing at AOS. “The buck topology in LED backlighting solutions offers our customers improved overall solution cost with reduced component count and smaller footprint on the PCB.”
Pricing and Availability
The AOZ1948 is immediately available in production quantities with a lead-time of 12 weeks. The unit price for 1,000 pieces is $0.495.
  • 时 间:2025.01.14
  • 公 司:ADI&DigiKey
