TI DRV8313具有三个独立可控的半H桥驱动器
关键词:TI DRV8313具 半H桥驱动器
时间:2013-03-25 14:56:54      来源:中电网
TI DRV8313具有三个独立可控的半H桥驱动器。它的目的是驱动三相无刷直流电动机(虽然它也可以被用来驱动螺线管或其它负载)。每个输出驱动器信道包括一个半H桥配置的N-通道功率MOSFET。
The DRV8313 provides three individually controllable half-H-bridge drivers. It is intended to drive a three-phase brushless dc motor, though it can also be used to drive solenoids or other loads. Each output driver channel consists of N-channel power MOSFETs configured in a half-H-bridge configuration. The design brings the ground terminals of each driver to pins, to allow one to perform current sensing on each output.
Current-limit circuitry or other functions are possible uses of an uncommitted comparator.
The DRV8313 can supply up to 2.5-A peak or 1.75-A rms output current per channel (with proper PCB heatsinking at 24 V and 25°C) per half-H-bridge.
The device provides internal shutdown functions for overcurrent protection, short-circuit protection, undervoltage lockout, and overtemperature.
The DRV8313 comes in a 28-pin HTSSOP PowerPAD package.
  • 时 间:2025.05.13
  • 公 司:英飞凌&增你強
  • 时 间:2025.05.14
  • 公 司:Arrow&ADI
