Maxim推出MAX20021/MAX20022电源管理IC
关键词:Maxim MAX20021/MAX20022 电源管理
时间:2013-04-01 09:40:09      来源:中电网
MAX20021/MAX20022电源管理IC(PMIC)集成了4个低电压,高效率,降压型DC-DC转换器。其四个输出为工厂或电阻可编程(1.0V至4.0V之间),可提供高达1.0A的电流。其PMIC工作电压为3.0V至5.5V,是汽车点载荷,和后控制的理想选择
The MAX20021/MAX20022 power-management ICs (PMICs) integrate four low-voltage, high-efficiency, step-down DC-DC converters. Each of the four outputs is factory or resistor programmable between 1.0V to 4.0V and can deliver up to 1.0A of current. The PMICs operate from 3.0V to 5.5V, making them ideal for automotive point-of-load and post-regulation applications.
The PMICs feature fixed-frequency PWM-mode operation with a switching frequency of 2.2MHz or 3.2MHz. High-frequency operation allows for an all-ceramic capacitor design and small-size external components. The low-resistance on-chip switches ensure high efficiency at heavy loads while minimizing critical inductances, making the layout a much simpler task with respect to discrete solutions. Internal current sensing and loop compensation reduce board space and system cost.
The PMICs offer a spread-spectrum option to reduce radiated emissions. Two of the four buck converters operate 180° out-of-phase with the internal clock. This feature reduces the necessary input capacitance and improves EMI as well. All four buck converters operate in constant-PWM mode outside the AM band. The PMICs offer a SYNC input to synchronize to an external clock.
The PMICs provide individual enable inputs and power-good/reset outputs, as well as factory-programmable active-low RESET times.
The PMICs offer several important protection features including: input overvoltage protection, input undervoltage monitoring, input undervoltage lockout, cycle-by-cycle current limiting, and overtemperature shutdown. The input undervoltage monitor indicates a brownout condition by driving PG_ low when the input falls below the UVM threshold.
The MAX20021/MAX20022 PMICs are available in a 28-pin TQFN package with an exposed pad and are specified for operation over the -40°C to +125°C automotive temperature range.
Key Features
Quad Step-Down DC-DC Converters with Integrated FETs Operate from 3.0V to 5.5V Supply Voltage 1.0V to 4.0V Fixed or Adjustable Output Voltage 2.2MHz or 3.2MHz Switching Frequency Two Output Current Configurations Two 1.0A Outputs and Two 500mA Outputs (MAX20021) Four 1.0A Outputs (MAX20022) Designed to Improve Automotive EMI Performance Forced-PWM Operation Two Channels 180º Out-of-Phase SYNC Input Spread-Spectrum Option Soft-Start and Supply Sequencing Reduces Inrush Current Individual Enable Inputs and Power-Good Outputs to Simplify Sequencing OV/UV Input-Voltage Monitoring Overtemperature and Short-Circuit Protection 28-Pin (5mm × 5mm × 0.8mm) TQFN-EP Package -40°C to +125°C Operating Temperature Range
  • 主 题:LED应用篇:使用时的关键要点
  • 时 间:2025.04.24
  • 时 间:2025.05.13
  • 公 司:英飞凌&增你強
  • 时 间:2025.05.14
  • 公 司:Arrow&ADI
