TI LM25017是一个48V、650毫安同步降压型稳压器
关键词:TI LM25017 同步降压型稳压器
时间:2013-04-02 11:28:03      来源:中电网
LM25017是一个48V,650毫安同步降压型稳压器,并具有集成高侧和低侧MOSFET。LM25017采用了恒定导通时间(COT)控制方案,无需环路补偿。它具有出色的瞬态响应,并具有非常低的降压比。其导通时间变化与输入电压成反比,从而,形成了输入电压范围上的,几乎恒定的频率。其高电压启动稳压器为IC内部运作,和集成门极驱动器提供了偏压电源
The LM25017 is a 48V, 650mA synchronous step-down regulator with integrated high side and low side MOSFETs. The constant-on-time (COT) control scheme employed in the LM25017 requires no loop compensation, provides excellent transient response, and enables very low step-down ratios. The on-time varies inversely with the input voltage resulting in nearly constant frequency over the input voltage range. A high voltage startup regulator provides bias power for internal operation of the IC and for integrated gate drivers.
A peak current limit circuit protects against overload conditions. The undervoltage lockout (UVLO) circuit allows the input undervoltage threshold and hysteresis to be independently programmed. Other protection features include thermal shutdown and bias supply undervoltage lockout (VCC UVLO).
The LM25017 is available in LLP-8 and PSOP-8 plastic packages.
Features
Integrated 48V, High and Low Side Switches No Schottky Required Constant On-time Control No Loop Compensation Required Ultra-Fast Transient Response Nearly Constant Operating Frequency Intelligent Peak Current Limit Adjustable Output Voltage from 1.225V Precision 2% Feedback Reference Frequency Adjustable to 1MHz Adjustable Undervoltage Lockout (UVLO) Remote Shutdown Thermal Shutdown
  • 时 间:2025.01.14
  • 公 司:ADI&DigiKey
