  • 首页 > 新品 > IXYS推出了一个83毫米裸片相位控制晶闸管产品系列的新产品
关键词:IXYS 晶闸管产品
时间:2013-04-07 14:10:01      来源:中电网
IXYS公司宣布,该公司的英国全资子公司,IXYS UK Westcode 有限公司,推出了一个83毫米裸片相位控制晶闸管产品系列的新产品。该新型晶闸管(额定电压为2200伏)是该公司最新产品,这种新产品采用了一个集成的裸片结构,和改进的封装设计,具有更好的机电性能和热性能。
IXYS Corporation announced that its wholly owned UK subsidiary, IXYS UK Westcode Ltd., launched a new addition to its 83mm die phase control thyristors product group. The thyristors, rated at 2200 volt, are the latest introduction to this new product group that uses an integrated die construction and improved package design for better electromechanical and thermal performances. The 2.2kV thyristor has an average current rating (Case temperature 55C) of 4340 amperes, with a junction to heat sink thermal resistance of 0.008 kelvins per watt. The new thyristor is constructed using an all diffused silicon wafer slice fused to a metal header and encapsulated in a fully hermetic package.
This construction enhances the performance and provides excellent transient thermal and surge current ratings. – “This new addition to the product group offers exceptional current rating for this voltage class and package size, thereby maximising the power to package ratio. Older ‘alloy free’ technology is very limited in its application at lower voltage classes. This new introduction takes advantage of better silicon wafer technology and therefore reduced forward voltage drop to achieve the higher current rating and therefore higher power rating. Maximising performance through improved technology is core to IXYS’ strategy to produce the most power efficient devices,” commented Frank Wakeman, IXYS UK’s Marketing & Technical Support Manager.
The device is available in two industry standard capsule heights and two different voltage grades. Designations are: one inch thick package N4340TJ220 (2200 Volts), N4340TJ180 (1800 Volts); one and a half inch thick package N4340TE220 (2200 Volts), N4340TE180 (1800 Volts). Additional products with voltage ratings up to 6500 volts will be launched through 2013. Typical applications for these devices include industrial drives, wind power converters, soft starters, excitation, utilities and controlled rectifiers.
For data sheets please go to the IXYS UK website at http://www.ixysuk.com or please contact us at (email: .(JavaScript must be enabled to view this email address) ) or telephone: +44 (0)1249 444524 for quotation.
  • 时 间:2025.07.31
  • 公 司:NXP
  • 主 题:Abracon高精度时钟在测量仪器中的应用
  • 时 间:2025.08.19
  • 公 司:Abracon
