Avago金属壳体光接收机HFBR-2555AFZ
关键词:Avago 金属壳体 光接收机 HFBR-2555AFZ
时间:2013-04-09 10:28:13      来源:中电网
HFBR-2555AFZ是一个金属壳体光接收机,用于SERCOS,其数据传输率为4,8和16兆位(MBd)。其金属外壳为防止光口破损提供了强大的保护,使其在恶劣的环境下具有卓越的ESD性能。其光学数据,通过光纤环,在数值控制和驱动之间传输,并具有电压隔离和抗噪声能力
HFBR-2555AFZ is a metal housing optical receiver for SERCOS applications that operates at data rates of 4, 8 and 16 MBd. The metal housing provides a robust design that prevent optical port breakage in the harsh environment with excellence ESD performance. The optical data is transferred between numerical controls and drives via fiber-optic rings, with voltage isolation and noise immunity.
HFBR-2555AFZ is designed to operate with transmitter HFBR-1505AFZ. This part is characterized with 200μm HCS® and 1mm POF cable for wide operating temperature from -40°C to +85°C
Features
Meets industrial SERCOS standard SMA ports 650 nm wavelength technology Metal housing and port Specified for use with 1 mm plastic optical fi ber and 200 µm hard clad silica Auto-insertable and wave solderable Supports SERCOS 4, 8 and 16 MBd RoHS-compliant
Signup for the Avago Now Newsletter:
http://www.avagotech.com/pages/contact/newsletter_signup/?WR.mc_id=EEweb_2013
  • 时 间:2025.01.14
  • 公 司:ADI&DigiKey
