Avago三通道光学编码器AEDR-850X
关键词:Avago 三通道光学编码器 AEDR-850X
时间:2013-04-09 10:36:55      来源:中电网
AEDR-850X编码器是世界上最小的三通道光学编码器。具有数字输出,采用反射式技术,用于运动控制。该编码器的工作温度为-20°C至85°C,因此适用于商业和工业的高端领域
The AEDR-850x encoder is the smallest 3 channel optical encoder in the world with digital outputs employing reflective technology for motion control purposes. The encoder is designed to operate over -20° C to 85° C temperature range and therefore is suitable for both commercial and industrial end applications.
This 3 channel optical encoder houses an LED light source and a photodetecting circuit in a single package. The small size of 3.95 mm (L) x 3.4 mm (W) x 0.9562 mm (H), allows it to be used in a wide range of miniature commercial applications where size and space constraints exist.
The AEDR-850x series encoders offer two-channel quadrature digital outputs and a 3rd channel, index digital outputs. Being TTL compatible, the outputs of the AEDR-850X 3 channel optical encoder can be interfaced directly with most of the signal processing circuitries. Hence the encoder provides great design-in flexibility and easy integration into existing systems.
Features
World smallest 3 channels reflective technology encoder. Surface mount leadless package 3.95 mm (L) x 3.4 mm(W) x 0.9562 mm (H) 3 channels; two channel quadrature digital outputs for direction sensing and a 3rd channel, Index digital output. Build in interpolator, factor of 1x, 2x and 4x selectable via external pinouts TTL compatible Single 5 V supply -20° C to 85° C absolute operating temperature Encoding resolution: 304 (lines/inch) or 12 (lines/mm) Index Gating, Un-gated 360º e
Signup for the Avago Now Newsletter:
http://www.avagotech.com/pages/contact/newsletter_signup/?WR.mc_id=EEweb_2013
  • 时 间:2025.07.31
  • 公 司:NXP
  • 主 题:Abracon高精度时钟在测量仪器中的应用
  • 时 间:2025.08.19
  • 公 司:Abracon
