  • 首页 > 新品 > Alliance Memory扩展高速CMOS同步DRAM(SDRAM)128M和256M产品的阵容
关键词:Alliance Memory CMOS DRAM SDRAM
时间:2013-04-10 16:39:51      来源:中电网
Alliance Memory公司推出了一款新产品,为54球8毫米,8毫米,1.2毫米TFBGA封装。该产品扩展了Alliance Memory公司的,高速CMOS同步DRAM(SDRAM)128M和256M产品的阵容。
Alliance Memory extended its 128M and 256M lines of high-speed CMOS synchronous DRAMs (SDRAM) with new devices in a 54-ball 8 mm by 8 mm by 1.2 mm TFBGA package. These 8M x 16 and 16M x 16 SDRAMs feature fast access time from clock down to 4.5 ns at a 5-ns clock and clock rates of 143 MHz.
The devices released today are optimized for medical, industrial, automotive, and telecom applications requiring high memory bandwidth, and are particularly well-suited to high-performance PC applications. The SDRAMs operate from a single +3.3-V (± 0.3 V) power supply and are lead (Pb)- and halogen-free.
The AS4C8M16S-7BCN and AS4C16M16S-7BCN provide programmable read or write burst lengths of 1, 2, 4, 8, or full page, with a burst termination option. An auto pre-charge function provides a self-timed row pre-charge initiated at the end of the burst sequence. Easy-to-use refresh functions include auto- or self-refresh while a programmable mode register allows the system to choose the most suitable modes to maximize performance.
Alliance Memory’s legacy ICs provide reliable drop-in, pin-for-pin-compatible replacements for a number of similar solutions. The AS4C8M16S-7BCN and AS4C16M16S-7BCN are the latest in the company’s full line of high-speed SDRAMs, which includes devices with densities of 16 Mb, 64 Mb, 128 Mb, 256 Mb, and 512 Mb in the 54-pin TSOP II, 54-ball TFBGA, 86-pin TSOP II, and 90-ball BGA packages.
Samples and production quantities of the new SDRAMs are available now, with lead times of six weeks for large orders. Pricing is $1.75 per piece for the AS4C8M16S-7BCN and $2.25 per piece for the AS4C16M16S-7BCN.
  • 时 间:2025.07.08
  • 公 司:DigiKey & TE
