TI推出即时D-CAP2模式同步降压转换器TPS54239
关键词:TI D-CAP2 TPS54239
时间:2013-04-16 15:23:47      来源:中电网
TPS54239是一个自适应,即时D-CAP2™模式同步降压转换器。 TPS54239具有低成本,低元件数,低待机电流的特性,可以协助系统设计工程师们完成各种终端设备的电源总线调节器的设计。TPS54239的主控制回路采用了D-CAP2™模式控制,可以提供快速瞬态响应,无需外部补偿组件。 TPS54239还具有专门的电路,用于低等效串联电阻(ESR)的输出电容(如POSCAP或SP-CAP),和超低ESR陶瓷电容器。该器件工作电压为4.5-V到23-V,输入V
The TPS54239 is an adaptive on-time D-CAP2™ mode synchronous buck converter. The TPS54239 enables system designers to complete the suite of various end-equipment power bus regulators with a cost effective, low component count, low standby current solution.
The main control loop for the TPS54239 uses the D-CAP2™ mode control that provides a fast transient response with no external compensation components. The TPS54239 also has a proprietary circuit that enables the device to adopt to both low equivalent series resistance (ESR) output capacitors, such as POSCAP or SP-CAP, and ultra-low ESR ceramic capacitors. The device operates from 4.5-V to 23-V VIN input. The output voltage can be programmed between 0.76 V and 7 V. The device also features an adjustable soft start time. The TPS54239 is available in the 8-pin DDA package, and designed to operate from –40°C to 85°C.
Features
D-CAP2 Mode Enables Fast Transient Response Low Output Ripple and Allows Ceramic Output Capacitor Wide VIN Input Voltage Range: 4.5 V to 23 V Output Voltage Range: 0.76 V to 7.0 V Highly Efficient Integrated FETs Optimized for Lower Duty Cycle Applications – 140 mΩ (High Side) and 70 mύ (Low Side) High Efficiency, less than 10 µA at shutdown High Initial Bandgap Reference Accuracy Adjustable Soft Start Pre-Biased Soft Start 600-kHz Switching Frequency (fSW) Cycle By Cycle Over Current Limit
  • 时 间:2025.07.31
  • 公 司:NXP
  • 主 题:Abracon高精度时钟在测量仪器中的应用
  • 时 间:2025.08.19
  • 公 司:Abracon
