Power的LinkSwitch-CV大大简化了要求苛刻的CV电源设计
关键词:Power LinkSwitch-CV CV电源设计
时间:2013-05-24 09:49:15      来源:中电网
Power的LinkSwitch-CV大大简化了要求苛刻的CV电源设计(通过省去光耦器和次级控制电路)。该器件采用了革新性的控制技术,能够提供极为严格的输出电压调节,和输入电压变化,以及温度。
The LinkSwitch-CV dramatically simplifies CV power supply design with tight CV requirements and by eliminating an optocoupler and secondary control circuitry. The device introduces a revolutionary control technique to provide very tight output voltage regulation, along with input voltage variations and temperature.
The device incorporates a 700 V power MOSFET, a novel On/Off control state machine, a high voltage switched current source for self biasing, frequency jittering, cycle-by-cycle current limit and hysteretic thermal shutdown circuitry onto a monolithic IC.
Dramatically Simplifies CV Converters
Eliminates optocoupler and all secondary CV control circuitry Eliminates bias winding supply – IC is self biasing
Advanced Performance Features
Compensates for external component temperature variations Very tight IC parameter tolerances using proprietary trimming technology Frequency jittering greatly reduces EMI filter cost Even tighter output tolerances achievable with external resistor selection/trimming
Advanced Protection/Safety Features
Auto-restart protection reduces delivered power by <95% for output short circuit and all control loop faults (open and shorted components) Hysteretic thermal shutdown – automatic recovery reduces power supply returns from the field Meets HV creepage requirements between Drain and all other pins, both on the PCB and at the package
Applications
DVD/STB
Adapters
Standby and auxiliary supplies
Home appliances, white goods and consumer electronics
Industrial controls
  • 主 题:LED应用篇:使用时的关键要点
  • 时 间:2025.04.24
  • 时 间:2025.05.13
  • 公 司:英飞凌&增你強
  • 时 间:2025.05.14
  • 公 司:Arrow&ADI
