Littelfuse无铅快速薄膜型保险丝466系列
关键词:Littelfuse 无铅快速薄膜型保险丝 466系列
时间:2013-06-05 15:27:15      来源:中电网
466系列快熔表面贴装保险丝(SMF)是一个小尺寸(1206)薄膜产品,用于空间受限产品的二级保护,如,手持式便携电子设备。该系列产品是100%无铅,符合RoHS规范要求……
The 466 Series Fast-Acting Surface Mount Fuse (SMF) is a small (1206 size) thin-film device designed for secondary protection of circuits used in space constrained applications such as hand-held portable electronic devices.
This series is 100% lead-free and meets the requirements of the RoHS directive. New Halogen-Free 466 Series fuses are available to order using the “HF” suffix.
Features:
Complies with electronic industry environmental standards for lead reduction. Product is compatible with lead-free solders and higher temperature profiles. Current ratings available up to 7A. If a 7A fuse is required please see the 429 series. High performance materials provide improved performance in elevated ambient temperature applications. Product is marked on top surface with code to allow amperage-rating identification without testing. Low profile for height sensitive applications. Flat top surface for pick-and-place operations. Element covering material is resistant to industry standard cleaning operations. Mounting pad and electrical performance is identical to Littelfuse 429 and 433 Series products. Alloy based element construction provides superior inrush withstand characteristics (l2t) over ceramic or glass based 1206 chip fuse products.
Applications:
Cell phones Battery packs Digital cameras DVD players Hard disk drives
  • 主 题:确保医疗设备安全可靠的解决方案
  • 时 间:2025.06.18
  • 公 司:DigiKey&Littelfuse
  • 时 间:2025.06.24
