Allegro MicroSystems推出新型的降压稳压器
关键词:Allegro MicroSystems 降压稳压器 A8580
时间:2013-06-08 17:29:50      来源:中电网
Allegro MicroSystems公司推出了一个新型的降压稳压器,它可以灵活地提供(4至40 V)输入电压,250 kHz至2.4 MHz的开关频率,和最高2.5 A的输出电流,适用于下一代汽车音响和信息娱乐系统的电源要求。Allegro公司的A8580具有控制和保护电路,形成了高电流稳压器,其输出电压精度为±1.0%
Allegro MicroSystems, LLC introduces a new buck regulator that offers significant flexibility in input voltage (4 to 40 V), switching frequency (250 kHz to 2.4 MHz), and output current (up to 2.5 A). Designed to provide the power supply requirements of next generation car audio and infotainment systems, Allegro’s A8580 provides the control and protection circuitry to produce a high current regulator with ±1.0% output voltage accuracy.
A key feature of the A8580 is the ability to employ pulse frequency modulation (PFM) for very low input current while supplying a “keep-alive” voltage supply. It is guaranteed to draw less than 50 μA from 12 VIN while supplying 3.3 V/40 μA. Also, to work down to idle-stop battery conditions, the A8580 will operate down to at least 3.6 VIN (VIN falling).
Other features of this new device include switching frequency clock synchronization, and an ultra-low current, shutdown mode requiring less than 5 μA. The A8580 has external compensation to accommodate a wide range of frequencies and external components, and provides a power on reset (NPOR) signal validated by the output voltage.
Extensive protection features include pulse-by-pulse current limit, hiccup mode short circuit protection, open/short asynchronous diode protection, BOOT pin open/short voltage protection, VIN under-voltage lockout, VOUT over-voltage protection and thermal shutdown.
The A8580 is available in a low profile 16-pin TSSOP package (suffix LP) with exposed pad for enhanced thermal dissipation.
  • 主 题:确保医疗设备安全可靠的解决方案
  • 时 间:2025.06.18
  • 公 司:DigiKey&Littelfuse
  • 时 间:2025.06.24
