Power推出一款新的IC CAPZero
关键词:Power CAPZero
时间:2013-06-26 15:04:58      来源:中电网
CAPZero是一款IC,它完全消除了X电容放电电阻的功耗。CAPZero是具有两个终端的移动器件,可以添加到任何具有X电容放电电阻的电源上,以减少无负载消耗,并提供更多的备用电源。它是一款简单的产品,很容易满足安全要求
CAPZero is an IC that completely eliminates the power dissipated by X capacitor discharge resistors. CAPZero is a two terminal device that can be added to any power supply with X capacitor discharge resistors to decrease no-load consumptions and provides more standby power. It is a simple product that easily meet safety requirements.
When AC voltage is applied, CAPZero blocks current flow in the X capacitor safety discharge resistors, reducing the power loss to less than 5 mW or essentially zero at 230 VAC. When AC voltage is disconnected, CAPZero automatically discharges the X capacitor by connecting the bleed resistors in parallel. This operation allows total flexibility in the choice of the X capacitor to optimize differential mode EMI filtering and reduce inductor costs with no change in power consumption.
The simplicity and ruggedness of the two terminal CAPZero chip makes it an ideal choice in systems designed to meet EuP Lot 6 requirements.
Applications
All AC/DC converters with X capacitors >100 nF Appliances requiring EuP Lot 6 compliance Adapters requiring ultra low no-load consumption All converters requiring very low standby power
  • 主 题:新一代光储系统解决方案
  • 时 间:2024.11.08
  • 公 司:Mouser & onsemi & 伍尔特电子
  • 主 题:自主移动机器人(AMR)平台方案介绍
  • 时 间:2024.11.19
  • 主 题:PIC®和AVR®单片机如何在常见应用中尽展所长
  • 时 间:2024.11.26
  • 公 司:DigiKey & Microchip
