Melexis推出MLX72013 ASK / FSK发送器IC
关键词:Melexis MLX72013 ASK/FSK发送器
时间:2013-06-26 15:07:43      来源:中电网
MLX72013 ASK / FSK发送器IC,是专为欧洲433MHz工业科学医疗(ISM)频带应用而设计的(根据EN300 220电信标准),但它也可以用在其他相似的标准,例如,FCC part 15.231。 该发射器的载波频率fc由参考晶体的频率fref而确定。
The MLX72013 ASK/FSK transmitter IC is designed for applications in the European 433MHz industrial-scientific-medical (ISM) band, according to the EN 300 220 telecommunications standard; but it can also be used in other counties with similar standards, e.g. FCC part 15.231.
The transmitter’s carrier frequency fc is determined by the frequency of the reference crystal fref. The integrated PLL synthesizer ensures that carrier frequencies, ranging from 425MHz to 445MHz, can be achieved. This is done by using a crystal with a reference frequency according to: fref = fc/N, where N = 16 is the PLL feedback divider ratio.
Features and Benefits
Fully integrated PLL-stabilized VCO Frequency range from 425 MHz to 445 MHz Single-ended RF output FSK through crystal pulling allows modulation from DC to 40 kbit/s High FSK deviation possible for wideband data transmission Wide power supply range from 1.95 V to 5.5 V Operating temperature range -40°C to +125°C Very low standby current On-chip low voltage detector High over-all frequency accuracy FSK deviation and center frequency independently adjustable Adjustable output power range from -16 dBm to +12 dBm Adjustable current consumption from 3.5 mA to 15.9 mA Conforms to EN 300 220 and similar standards
  • 时 间:2025.07.31
  • 公 司:NXP
