TI推出高边电流感应放大器LMP8480和LMP8481
关键词:TI 高边电流感应放大器 LMP8480 LMP8481
时间:2013-06-28 14:49:46      来源:中电网
LMP8480和LMP8481是高精度高边电流感应放大器,可以放大小差分电压(在高输入共模电压时,由电流感应电阻产生)。
The LMP8480 and LMP8481 are precision high-side current sense amplifiers that amplify a small differential voltage developed across a current sense resistor in the presence of high input common-mode voltages.
These amplifiers are designed for bidirectional (LMP8481) or unidirectional (LMP8480) current applications and will accept input signals with common-mode voltage range from 4V to 76V with a bandwidth of 270 kHz.
Since the operating power supply range overlaps the input common mode voltage range, the LMP848x can be powered by the same voltage that is being monitored. This benefit eliminates the need for an intermediate supply voltage to be routed to the point of load where the current is being monitored, resulting in reduced component count and board space.
The LMP848x family consists of fixed gains of 20, 50, 60 and 100 for applications that demand high accuracy over temperature. The low input offset voltage allows the use of smaller sense resistors without sacrificing system error.
The wide operating temperature range of -40C to 125C makes the LMP848x an ideal choice for automotive, telecommunications, industrial, and consumer applications.
The LMP8480 and LMP8481 are pin for pin replacements for the MAX4080 and MAX4081, offering improved offset voltage, wider reference adjust range and higher output drive capabilities.
The LMP8480 and LMP8481 are available in a 8-pin MSOP package and the LMP8481 is also available in a 8–pad LLP.
Features
Typical values, TA = 25°C Bi-Directional or Uni-Directional Sensing Common Mode Voltage Range 4.0V to 76V Supply Voltage Range 4.5V to 76V Fixed Gains 20, 50, 60 and 100 V/V Gain Accuracy ±0.1% Offset ±80µV Bandwidth (–3dB) 270KHz Quiescent Current <100µA Buffered High-Current Output >5mA Input Bias Current 7µA PSRR (DC) 122dB CMRR (DC) 124dB Temperature Range –40 to +125°C MSOP-8 or LLP-8 Packages
