Microchip MCP2210是一个USB至SPI主转换器
关键词:Microchip MCP2210
时间:2013-07-04 17:09:09      来源:中电网
MCP2210是一个USB至SPI主转换器,它可以与具有SPI接口的器件进行USB连接。该器件通过集成USB端接电阻,减少了外部元件的数量。
The MCP2210 device is a USB-to-SPI Master converter which enables USB connectivity in applications that have an SPI interface. The device reduces external components by integrating the USB termination resistors. The MCP2210 also has 256 bytes of integrated user EEPROM. The MCP2210 has nine general purpose input/output pins. Seven pins have alternate functions to indicate USB and communication status.
Universal Serial Bus (USB
Supports full-speed USB (12 Mb/s) Human Interface Device (HID) device 128-byte Buffer to handle data throughput: 64-byte transmit 64-byte receive Fully configurable VID, PID assignments and string descriptors Bus powered (factory default) or self-powered (can be selected through special USB commands) USB 2.0 Compliant
USB Driver and Software Support
Uses standard HID drivers (built-in support on Windows® XP, Vista, 7, Linux and Mac OS®) Configuration utility for device’s power-up configuration Utility for USB-SPI communication, GPIO manipulation and miscellaneous features usage
  • 时 间:2025.01.14
  • 公 司:ADI&DigiKey
