TI推出TPS3831和TPS3839超低电流电压监控电路
关键词:TI TPS3831 TPS3839
时间:2013-03-18 11:09:04      来源:中电网
TI推出TPS3831和TPS3839超低电流电压监控电路,用来监视单一的电压,当VDD电源电压低于工厂校准的复位阈值电压时,这两款器件都有低电有效复位信号。
The TPS3831 and TPS3839 (both referred to as the TPS383x) are ultralow current (150 nA, typical), voltage supervisory circuit that monitor a single voltage. Both devices assert an active-low reset signal whenever the VDD supply voltage drops below the factory-trimmed reset threshold voltage. The reset output remains asserted for 200 ms (typical) after the VDD voltage rises above the threshold voltage. These devices are designed to ignore fast transients on the VDD pin. Note that the TPS3831 includes a manual reset input.
The ultralow current consumption of 150 nA makes these voltage supervisors ideal for use in low-power and portable applications. The TPS383x are specified to have the correct output logic state for supply voltages down to 0.6 V.
The TPS383x feature precision factory-trimmed threshold voltages and extremely low-power operation. The TPS3831 is available is a 4-pin 1-mm × 1-mm (DQN) X2SON package. The TPS3839 is available in a 3-pin SOT23 (DBZ) package or a 4-pin 1-mm × 1-mm (DQN) X2SON package.
Features
Ultralow Supply Current: 150 nA (typ) Operating Supply Voltage: 0.6 V to 6.5 V Valid Reset for VDD > 0.6V Push-Pull RESET Output Factory-Trimmed Reset Threshold Voltages Temperature Range: –40°C to +85°C Packages: 1-mm × 1-mm X2SON or 3-Pin SOT23
TPS383x
  • 主 题:英飞凌汽车方案引领智能座舱新纪元
  • 时 间:2025.03.12
  • 公 司:英飞凌&品佳集团
  • 主 题:便携式电子产品与 AI 时代下的 WiFi 与 BLE 技术革新
  • 时 间:2025.03.25
  • 公 司:Arrow&村田
