Melexis推出完全集成的LIN从动装置MLX80105
关键词:Melexis MLX80105
时间:2013-05-13 14:06:50      来源:中电网
MLX80105是一个完全集成的LIN从动装置,用于汽车的开关,或类似的IO-控制/扩展。它适用于总线系统(根据LIN2.x和SAE J2602)。所有必要的组件都集成到一个单一的硅芯片上。
The MLX80105 is a fully integrated LIN slave for switch or similar IO-Control/Extension Applications in automotive. It is suitable for bus systems according to LIN 2.x as well as SAE J2602. All necessary components are integrated into one single silicon die. The MLX80105 consists of a microcontroller, voltage regulator, LIN physical Layer, LIN Protocol Driver, ADC, PWM as well as high voltage IOs. The combination of a physical layer LIN transceiver and a LIN protocol controller along with easy to configure switch inputs and PWM outputs makes it possible to develop simple, but powerful and cheap switch slave nodes for LIN Bus systems in a short timeframe.
MLX80105 Features and Benefits
Application Controller
Internal 12 MHz RC-Oscillator
16-bit MULAN MCU with 16kB OTP, 512 Byte RAM, 192 Byte EEPROM with ECC
LIN Protocol Controller according to LIN 2.x and SAE J2602
Baud rate up to 19.2 kBaud
Frame processing
Low interrupt load to the application
LIN Transceiver according to LIN 2.x and SAE J2602
Slew rate control for best EME behaviour
High EMI immunity
IO Configuration
18 fully configurable high current/high voltage inputs/outputs (7mA/26.5V)
Ground shift tolerant I/Os
All IOs configurable pull up or pull down characteristics
Eight PWM outputs (8-bit, 80Hz to 30kHz)
Ten 10-bit ADC channels
Eight Interrupt capable Inputs
Configurable Wake up sources (LIN, IOs, ADC)
Constant current output (2mA) for external low voltage loads via bipolar transistor
IOs fully diagnosable
Integrated window watchdog and additional independent analogue watchdog
Voltage Regulator
Low standby current consumption of typ 25µA in sleep mode
Over-temperature shutdown, 45V load dump protected
Other Features
Automotive Temperature Range of –40°C to 125°C
Small MLF 5×5 28pin package
  • 时 间:2025.01.14
  • 公 司:ADI&DigiKey
